Multisim and Ultiboard
Multisim and Ultiboard Training Courses
Hi Ganesh,
Spice models for parts are developed by the manufacturers. I searched intersil's website but there is no spice model available for this part. This is basically a voltage controlled function generator which you can easily simulate using some of the voltage controlled sources provided in the Multisim Database. Go to the Sources Group and the CONTROLLED_VOLTAGE_SOURCES faimily. You can find voltage controlled sine/square/triangle wave generators.
Please start a new post in the future when you have any questions or repy to a related one.
Hope this helps.
Tayyab R,
National Instruments.
Message 11 of 15
(2,531 Views)
Thank you  very much sir,will try out this.
regards
Ganesh
Message 12 of 15
(2,527 Views)
Good afternoon
I apologize using Google translator
assembled circuit on the power supply NCP1014, replacing the diodes D1 or D2 on DIODE_RATED with sufficient par, component failure occurs, for example D1 1000V, please tell me where the mistake, or maybe there are any features of the application components RATED_VIRTUAL.
Thanks in advance.
Message 13 of 15
(2,333 Views)
Hi fernando
please could you help me to gett software for multisim and labview i tried to make dowload but i couldn't.
Rgds
Antonio  Lourenco
Message 14 of 15
(1,822 Views)
Hi Antonio,
The links where you can download Multisim and LabVIEW are below:
http://www.ni.com/multisim/try/
http://www.ni.com/trylabview/
You can find the instruction to download and install Multisim here:
http://www.ni.com/tutorial/14581/en/
Tien P.
Message 15 of 15
(1,796 Views)
