01-29-2011 12:29 PM
Why are such common components such as the LM386 not included in Multisim 11.0.1?
Multisim is by far the best software of it's kind out there. I cannot understand why it doesn't have such common components included.
Many people (myself included) are not able to understand all the steps in the component creating wizard.
01-31-2011 02:10 PM
I found a SPICE model for the LM386 and created a simple tutorial on how to create this component in Multisim (for simulation only).
I also built a test circuit and the component seems to be working fine (see the file LM386.ms11).
Here are two more resources:
Creating a Custom Component in NI Multisim
Video: Creating a Custom Component in NI Multisim
I hope this helps.
04-24-2012 12:29 PM
can any body tell me which labview vertion is supportid by multisim 11.0.1
04-25-2012 01:01 PM
Multisim 11 can support from LabVIEW 8.5 to LabVIEW 2010.
04-26-2012 01:46 AM
how i can get FFT of a Circuit which is designed in multisim.....using labview 8.5......pls tell me sir
if possible then mail me full procedure....at sachinguptajazz@gmail.com
04-26-2012 11:13 AM
You will need to use the LabVIEW Multisim Toolkit. You can download it from the link below:
https://lumen.ni.com/nicif/us/evalmultisimtlkt/content.xhtml
Here is a page explaining the toolkit and how to use it.
http://zone.ni.com/devzone/cda/tut/p/id/7785
Hope this helps.
07-11-2013 01:46 AM
Hi friend, I followed every step you gave but still the chip LM386 I built does not work on Multisim. Is there any testing I can follow to check what part goes wrong? Thanks!
07-11-2013 08:41 AM
atoms,
In this document: http://forums.ni.com/ni/attachments/ni/370/9159/1/How%20to_LM386.pdf ,
step 12 is where most users get confused (this is the symbol - model mapping step).
If you have your component placed in a circuit, please post, and we can certainly look at it and verify what has gone wrong in the creation process...
Pat Noonan
