Multisim and Ultiboard
I have a Bandpass filter designed and am not getting the bandpass funtion on my bode plotter can someone help
I have a gircuit designed that i am not getting the bandpass result that is desired.  I have checked all the calculations and still getting nothing.  I get a huge dB loss in the middle of the plot and then a huge dB spike follwing that on the plotter please help.  I have attached the file to the post
(4,087 Views)
Actually it is working but your not using the equipment correctly.  You need to set the generator from 10Hz to 10Khz.  You need to set the initial and final values of the bode plot from say 4k initial to 20khz final and the input to 0db and final to 50db.  You also forgot to ground the output ground terminal of the bode plot.......try that.  The second order is pretty sharp appears to working.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,080 Views)
(4,078 Views)
