03-18-2014 03:21 PM
I have a csv file that was converted to a tdms file through a labview circuit. I am trying to use this tdms file to implement a source in Multisim. On the oscilloscope in labvuew it is outputting the right thing, but when I put it on the tdms source it is not. Could someone help me out? I am attaching relevant files (the vcs file and the converter labview design)
03-21-2014 10:48 AM
I am not sure why you want to do because you can save your noise data as a text file and import it directly to Multisim. The only reason why you would want to bring a tdm file into Multisim is if your VI is setup to save tdm file and don't want to convert the data.
In Multisim use a Piece Linear Wise (PWL) source, it's located under the "Sources" group, "Signal voltage source" family. Place the source on the workspace, double-click and there should be an option to load a .txt file.
