NI Home
Cart Cart | Help
You are here:
Reply
Member
Felipevv
Accepted Solution
Co-Simulation Multisim / LabVIEW
Is it possible to add two-state contacts to Multisim and control them from LabVIEW in a boolean way?
attached example diagram.
Member
Sharanya_R
Re: Co-Simulation Multisim / LabVIEW
[ Edited ]
I have attached a sample circuit with LabVIEW co-simulation.  This circuit uses a voltage controlled switch.  To control it from LabVIEW a connector is used that is taking in an input from the LabVIEW interface and the signal being generated is viewed using the graph utilities in LabVIEW.  The input from LabVIEW controlling the switch is a toggle control.
The link provided will give you information about co-simulation requirements
http://www.ni.com/white-paper/13663/en
If you have any other questions please let me know.
Sharanya R
Market Development Engineer
Member
Felipevv
Thanks, I knew that solution.
In the future, would be nice a more intuitive boolean way to control switches from labview to validate functional DC schemes.
Thank you very much.
Member
srividya d
Dear  sir/madam
       i m beginner for cosimulation of multisim with labview.... i started with example summer which is available in help.i can do succesfully till placing external library,while selecting multisim design through this external library to labview i m facing an error like"Configuration Error : Error-2367 occured at External Model.unavailable to load library" and sometimes it is giving "bad DLL image"..please
help me out....
        Regrads
        srividya
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
