06-06-2012 02:51 PM
Strange values on output of this simple buffer.
06-11-2012 09:42 AM
cforte,
It does appear that this model for the AD8031 (and the variations for the AD8032) in Multisim v12 has some issues and is incorrect, however, in the updated model version for the AD803X it does look like it has been updated (so in future Multisim updates it should be fixed).
In the mean time, here is an updated version of the AD8031 for you and others:
Pat Noonan
NI
03-21-2014 03:26 AM
Hi!
I try to use the AD8032 in Multisim v13 and the output of the amplifier still doesn't seem to work. Can you do something with that?
Krzysztof
03-24-2014 09:36 AM
Hi Ksielewi,
Please post the Multisim file, I can have a lot at it.
03-24-2014 09:36 AM
Hi Ksielewi,
04-02-2014 06:50 AM - edited 04-02-2014 06:51 AM
I attach the file.
As you'll see from the simulation the output of AD8031 is high all the time. There must be something wrong with the opamp spice model.
Krzysztof
04-03-2014 11:01 AM
Hi Krzysztof,
It doesn't look like AD8031 model will work with a single rail voltage source. Try the models mention in the following page:
http://www.analog.com/library/analogdialogue/archives/42-05/clock_buffer.html
Also, you should avoid using zero ohm resistors it can potentially be divided by 0 and it can cause convergence errors.
