Certification
"Application Directory" function vs. "Current VI's Path"
Several of the CLD Success Package examples call up files using the "Current VI's Path" function, then a "Strip Path," then a "Build Path."  It seems simpler to use the "Application Directory" function, then a "Build Path."  Is there a reason that people use "Current VI's Path" instead?
Thanks very much.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,570 Views)
Here are my rules:
For external files (text files, config files, etc) use Application Directory
For dynamically called VIs use Current VI's Path
I use these rules so that the rules do not change when I build an executable.
As far as the exam is concerned, I doubt you would be marked for either solution.
GCentral
(3,569 Views)
