NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
george.sterpu
clad sample exam 1 question
Hi.
I noticed this question in the clad sample exam 1
Which of the following statements is FALSE?
a. A SubVI connector pane defines where to wire inputs and outputs
b. The color of a SubVI connector pane terminal matches the data type it is connected to
c. You must have an icon/connector pane to use a SubVI
d. A SubVI icon can be edited from the functions palette
 In the answers it says D.
Wouldn't 'C' be the right answer ? I know that the icon is optional, but you must build the connector pane to use a sub vi.
Nevertheless, I found an invoke node (VI Icon -> Set from file/image data) that can edit the vi icon, therefore you could pick a vi server reference and an invoke node, all from the functions palette.
What do you guys think ?
Thanks.
Knight of NI
RavensFan
Re: clad sample exam 1 question
Nope D is the correct answer.
For C, you must have a connector pane in a subVI.  (Of course it is possible to have no terminals setup on it, or even no wires wired to it even if there are terminals set up.)  Any every subVI has an icon, it is not optional.  It might be the default icon from LabVIEW, or even a blank one, but it is always there.
For D, no you can't edit it from the functions palette.  I had actually never come across that invoke node you mentioned.  I don't think it is one that 99.9% of LV programmers would ever use.  I'd argue that you aren't editing the icon with that from the palette.  Yes you did grab it from a palette.  But really it is just a way to programmatically set the icon, you're not actually doing any "editing" with it.
Member
SercoSteveB
Hi George
If you are interested in other CLAD style questions:  Check out 'The Daily CLAD' blog
Steve
Check out my blog at ni.com. https://decibel.ni.com/content/blogs/DailyCLAD
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
