04-23-2017 01:20 PM
Does anyone have any good tips for setting up their LabVIEW environment for the CLD. I know everyone has their our preferences, but currently I don't really have any outside of going to options>Block Diagram>Tip Strips and Labeling and checking "Subdiagram labels visable by default" This help remind me to comment my diagrams.
Any inputs will be helpful.
04-24-2017 07:55 AM
This is pretty specific to an individuals preferences. And at one point I think NI allowed you to bring in your own LabVIEW.ini.
When I last took my certification I was given something like 5 or 10 minutes to setup my environment the way I want and for me that was things like turning off auto tool, turning off Place front panel terminals as icons, pinning the palettes and going to Customize >> Change Visible Palettes, and I setup all the common quick drop shortcuts that I use (because that wasn't part of LabVIEW at the time). Beyond that things like auto grow, or auto wiring, or the position of labels on terminals, are all things one developer might like and another hate.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-25-2017 05:46 PM
They won't let you bring your own ini. Which sucks. But it does make sense since you should not need all those ini keys I keep around. Know what you change from default. Then change em. If you do not have default pallets (control and function) remember to get them set up fast. Or QD your heart out.
04-26-2017 08:37 AM
Is there a way to auto wire so that once you connect the wire it straightens?
04-26-2017 09:02 AM
Explain and show an example of desired and undesired outcomes.
"Autowire" has a specific LabVIEW ini context. Somehow I don't think that is what you mean.
Spacebar while wiring has some advantages but is not related to autowire.
Appropriate connector pane patterns can help keep wires straight.
Setting the BD grid options to a multiple of Shift+Arrow pixels can help, as can enabling grid alignment.
Ctrl+U options include several settings that you should mess with on a slow day.
Again, "Thou shall know thine ini and keep it on a keychain." ought to be a LabVIEW commandmant
04-26-2017 09:24 AM
Ok. I feel a little slow at the moment. What is this "LabVIEW.ini" I thought I know what it was, but not I'm feeling like I don't. Is this a file that is created once you make a project? Is there a discussion board on it?
04-26-2017 09:33 AM
Tools>>Options is the basic editor dialog for the config file named "LabVIEW.ini" That file holds a lot of setting like; where to show floating panels (Tools pallet, QD dialog, Controls Pallet, etc....), what BD Cleanup options you want, what color you want your coercion dots to be (Input only you, cannot change the color of a coercion dot on an output) Blink rate for new vis. LOTS of things.
You should look at that text file and do a google search
05-09-2017 09:47 AM
I remember bringing my LabVIEW.ini to the CLD and CLA I took. I had it on a thumb drive and remember asking the exam proctor if I could change out the ini file (I told them they could sit and watch me to it if they wanted). I wouldn't look at my experience as how it was supposed to be handled but it can't hurt to ask.
