Certification
Thermostat please send me the same example
Hi Can any one please send me the Thermostat example and coffee machine examples.
Desparetly waiting for the  answeres
Message 1 of 15
(13,153 Views)
Why do you think the Coffee and Thermostat are available? I'm curious if this was said or mentioned or if it was just a mis-understanding?
The sample exams are available on the e-kit page.  Be sure to use the CLD success Package too!
E-Kit for CLD
The models you are referring to are the actual exams.  These are not available.  From the prep guide, the following models are the exam scenarios:
" CLD Exams
The following table lists possible exam scenarios that you may receive to develop a solution for your CLD exam.  This list is intended to give a general idea of what exams will be administered, and there may be variations within each exam.
Exam Scenario
Description
Coffee machine
The coffee machine simulates ingredient storage, and performs grinding, brewing and dispensing operations to prepare hot water, coffee and latte.
Microwave oven
The microwave oven simulates manual or pre-configured staged, recipe based cooking.
Security system
The multi-zoned security system simulates the arming, disarming, tamper, bypass and alarm functions.
Thermostat
The thermostat simulates scheduled programmatic heating and cooling control for heating, ventilation and air-conditioning (HVAC) system.
Treadmill
The treadmill simulates manual or multi-staged program mode that controls speed, incline, time and tracks run time and distance.
Vending machine
The vending machine simulates the storage, purchase, and dispensing of products using U.S. currency.
Mark Ramsdale
Program Manager & CLA
Global Demo and Equipment at National Instruments
Message 2 of 15
(13,151 Views)
the reason y i am asking is today i took CLD exam and i spent 1 to 1.5 hours iin understanding the requiment .if i get the sample paper ,i can get ready at least by understanding the reqyuirement,by the  way i got thermostat exmaple.i culs not able to completly understand the requirement
Message 3 of 15
(13,142 Views)
Ah.   Ok, thanks for the clarification.
We are not able to send the test materials out prior to the exam.
Mark Ramsdale
Message 4 of 15
(13,136 Views)
I am requesting to get only the questions , that too not exactly the same one , u can send me some similar examples.
But I am very much intrested to get the thread mill, thermostate, coffee machine, examples.some one will definately  put on the net.i am planning to take exame after couple of weeks
Message 5 of 15
(13,126 Views)
Please see the E-Kit above for sample exams and exercises.
Mark Ramsdale
Message 6 of 15
(13,120 Views)
Well, reading and understanding the requirements IS an integral part of the test, and doing it outside the allocated test time (before the test) would invalidate the results.
If you cannot understand the requirements document in a reasonable time that leaves enough time to write the code, maybe you are not ready for the CLD yet.
Message 7 of 15
(13,097 Views)
Smiley Very HappySmiley LOLSmiley LOL
@ C.A. Don't let that CLD go to your head!
"Should be" isn't "Is" -Jay
Message 8 of 15
(13,091 Views)
In the practice exams I find that little Adobe pdf yellow highlighter indispensable in grouping the requirements in the pdf. An electronic copy of the pdf, when taking the CLD, would be helpful in that manner. Otherwise there is a lot of flipping back and forth through the paper document.
Jim Haas
Message 9 of 15
(11,901 Views)
are we allowed to use a colored marker during exam? 🙂
Message 10 of 15
(11,825 Views)
