Certification
Simulated vs Hardware on CLA ATM Exam
I have been going through the ATM Example for the CLA exam.  I don't see where the physical hardware calls are.  It says in the requirements " For each module, the client must have the ability to choose either a simulated or hardware module"  Where is that choice in the example?
Dan Shangraw, P.E.
(4,310 Views)
The examples are generally submissions that passed.  Not necessarilly submissions that passed with perfect marks.  The fact that you are able to determine flaws in the example shows that you may be on the right track to pass the exam.
"Should be" isn't "Is" -Jay
(4,233 Views)
I hope so.  It is really hard not to code up the entire thing.  Figuring out where to draw the line will be tricky.
Dan Shangraw, P.E.
(4,223 Views)
In the CLA you are not required to code any function.
You must create the framework where the developer later should place the functions.
If your code runs you made something wrong.
Guilherme Correa
(3,920 Views)
