05-07-2017 08:17 PM
Can you upload for an older version? I'm on 2014 right now, but if you do 2012 or so you can get an even larger audience.
05-07-2017 08:24 PM
Ah, sorry. This is saved for 13.0 - I tried 12 but got a warning about 'Attachment' missing. Not quite sure what that is but guess I used something not available in LabVIEW 2012.
05-07-2017 08:41 PM
The functionality seems to be working well (just did a quick run through). I don't personally make heavy use of property nodes to set UI elements, but it should be ok. I did notice a couple of default icons (on clusters) that should at least have a text icon. I think you're well on your way to passing the test!
06-21-2017 05:53 AM - edited 06-21-2017 06:00 AM
Hello all,
I am planning to take CLD in two weeks. I tried to take one sample exam. I have attached Car Wash sample exam here. It is developed in LabVIEW 2015. Need someone to check it and give me feedback. Let me know if someone needs it in any other LabVIEW version, I will save it and upload it again.
Thank you in advance 🙂
Edit: Also uploading LabVIEW 2012 format.
06-21-2017 06:22 AM
Looks pretty good to me, although I only recently passed CLD.
Some points to note:
Good luck and nice work.
06-21-2017 06:34 AM
Thank you very much for the quick review.
I would like to put few points. First I normally use objects in my regular development but I am not sure if I should use it in the CLD exam. I am more comfortable with project file but again did not use it because I did not see any example test using it. I tried to follow the architecture what I saw in other examples.
Is it ok to use objects in the CLD exam? It would simplify the work on great extent also it will be modular. I don't want it to look like overdo.
Appreciate your help.
06-21-2017 06:39 AM
You can definitely use objects if you want. The point usually given as a cautionary thought is that you need to make sure you don't spend too long setting up architecture. There's no restriction against, but no bonus points for, using LVOOP. That being said, it can make compartmentalisation easier, and you get VI Icons that are non-default almost for free.
06-21-2017 07:28 AM
I'll add some points:
1. Front panel is not documented - all controls/indicators on the front panel must have description/tips.
2. For enums better to use typedef enums (I mean in Timer.vi).
3. I don't think that there will be problem with block diagram size - currect monitors have high resolution, plus with LabVIEW 2016 + you have such a big palletes, that old rule for small FP or BD size, I guess, is not applicable. But, keep in mind, that you can achieve that at least your code blocks will be scrolled just in one direction.
4. Event structure - either not use it at all, or put it inside of the case structure. Basically, if you need to catch just value of button Stop, you don't need event structure at all.
5. I guess, no need to use case structure on the upper level - anyway, this module is stand-alone. But it's up to you.
And, as it was told before, you can use VI Analyzer tool on the exam, to evaluate your VI; it could really help.
06-21-2017 08:07 AM
Thank you for the feedback.
07-06-2017 10:01 AM
I'm taking the CLD in a few weeks. Would someone be able to give me some review tips?
I've attached the Sprinkler example (LV2014).
Thanks!!
Nico
