08-08-2016 11:58 AM
Hi All,
Please Review my sprinkler sample exam using PC design.
I would like request all of you please provide useful feedback for my CLD exam.
Thanks in advance.
Hemant Chourasia
08-11-2016 08:43 AM
Can any body please review my coding and provide some useful feedback.
Hemant
08-11-2016 02:57 PM
Can you try posting it again? I got an error trying to extract the files.
08-12-2016 12:47 PM
I have also checked, not able to open. Error Reporting
Thanks for your info.
Please see the new attached file below.
Hemant
08-16-2016 08:27 AM
1.Wire bendings needs to be corrected as a whole looks good but in few areas needs to be corrected.
2.As 2 Loops are handled names can be provided separately for readability
3.In the Execution Loop (State-> Setup Constant is enabled with name as disabled)
4.Assume my initial value for pressure is 70 and i start then also i Low pressure message is displayed
5.Hope Wait until can be used instead of Wait.
08-16-2016 08:46 AM
The biggest thing I noticed and think you would get a lot of points off for is your documentation. I think the functionality and style are okay (you should really be using a project) but you don't have a single label in your main VI which is a lot of easy points on this exam.
08-17-2016 12:37 PM
Thanks Palanivel for such a useful feedback.
When i will do other sample exam, i will keep your suggestion in mind.
Hemant
08-17-2016 12:39 PM
Thanks Matt.
I will do the proper documentation in the comming perparation.
Do you have any other feedback apart from the documentation?/
Hemant
09-26-2016 09:15 PM
@Jacobson-ni wrote:The biggest thing I noticed and think you would get a lot of points off for is your documentation. I think the functionality and style are okay (you should really be using a project) but you don't have a single label in your main VI which is a lot of easy points on this exam.
Current instructions REQUIRE the use of the *.lvproj provided with the exam materials in order to even be graded. Read that simply as "If you don't use a project you won't get a grade hence: you cannot recieve a passing grade" Grade=NaN.
09-27-2016 07:48 AM
Good to know Jeff. I figured as much but didn't read the rules carefully enough to know that it was that required.
