Certification
NI CLAD Exam Queries
hi,
    Q1. Today I have attended CLAD exam, I have secured 67%(Pass grade:70%).i have few queries about my wrong answers and more over if I have any queries about my wrong CLAD answers.whom should I contact, Is there any NI department to help?
Q2 1.How many elements in the given 1D array (Pic: Array elements)
My answers:3
2.What is the answer for this question(Error cluster)
(4,393 Views)
Accepted by topic author rajkumar5
Q1: Contact certification@ni.com
Q2.1: 3 elements (the 4th position is grayed out, so does not play role in the array)
Q2.2: I think you forgot to attach the full question. Anyway, the block diagram has the problem that if there is an error, the error case of the outer Case will execute. So this BD will only clear warnings. Since I cannot see what is in the Error case of the outer Case structure, cannot comment further.
By the way, for such questions post in the dedicated forum board: http://forums.ni.com/t5/Certification/bd-p/Certification
Edit: ok, the Q2.1 is a tricky question (i really do not like these) maybe? So I would say, the array shows 4 elements, but the size of the array is 3...
(4,374 Views)
Hi rajkumar5
Please be very careful posting exam follow-up questions to the forum.  If an example is not pulled directly from the sample exams you risk the appearance of (or actual) violation of the Non-Disclosure Agreement, which could produce serious sanctions.  Questions like this are best sent directly to NI Certification at certification@ni.com.  We can respond to limited queries directly, with the communication covered under the NDA.
Best Regards,
Certification Engineer II
Certified LabVIEW Developer
(4,298 Views)
Ok thank you,I will contact certification@ni.com for further queries
(4,290 Views)
Hi rajkumar5
Check out The Daily CLAD blog for an additional CLAD preparation resource.
Regards
Steve
(4,250 Views)
