Certification
Initialize Array then Replace Items vs. Build Array
The CLD Success package example solutions tend to initialize and array, which is fed into a for loop, then replace the array elements withing the for loop.  I have always built such arrays using the "Build Array" function and starting the shift register off with an empty array.  Is the Initialize/Replace structure prefered?
Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,211 Views)
The Initialize and Replace is more efficient since it does not require more memory to be acquired each time you add an element.
But if you are working in a FOR loop, I would just use the Autoindexing Tunnels.  They can be conditional if you need that as well.
GCentral
(3,210 Views)
