Certification
How to avoid coercion dot when building array of references of different data type.
For disabling or enabling wanna a create a one SubVI for disabling or enabling controls instead of creating separate property node for individual controls.
When building array of references of different data type, getting coercion dot at inputs of build array(which is against the CLD style or generally its require to avoid coercion dot.)
Can anybody help in the above issue.??
Hemant
(3,964 Views)
Accepted by topic author LV_COder
You could use To More Generic Class.  If I barely failed because of those coercion dots, I would ask to argue the results.
GCentral
(3,951 Views)
Thanks Crossrule for your answer.
So its means for every control one TO MORE GENERIC CLASS function VI, Right??
Hemant
(3,934 Views)
Hemant
Actually, I believe crossrulz said "the coersion dot in this case is fine"  The referencec are being coerced to a more generic class  The property "Enabled" is common to all control objects.  So, no big deal for that coersion (and, it may be safer than "To more generic class")  Now, if you really still want to get rid of those coersion dots.... Just shut them off in the LabVIEW.ini
"Should be" isn't "Is" -Jay
(3,569 Views)
