07-08-2015 01:23 PM
@Hooovahh wrote:
@crossrulz wrote:Not quite. You are allowed to set up the environment before the exam. No user libraries, but you can at least set up your QuickDrop shortcuts and some other preferences.
Right, I was hoping I could bring along my LabVIEW.ini but I was given 10 minutes to setup my machine, which was more than enough. I setup my machine the best I could in the Tools >> Options, then went through and added all the common quick drop commands I could remember using. No OpenG was a bummer because I'm so used to having them, but I didn't really need them.
Nice point guys.
The proctors WILL typically allow you some few minutes to set up the enviornment. You cannot load anything from electronic media and you cannot have written notes or notes on media. So, one more tip from me!
Bring your A-Game:
Being able to just slam though and configure MyLabview and knowing the IDE needed to restart for some options (Palette views and load options especially) gave me a serious edge on both my attempts. Those little frustrations like Auto-tool getting in the way, where are my functions in this view, Oh Crud! the shipping VIT for PC (Events) exits the consumer on Queue destruction not a shut down command, ect.. can really add up and distract you while you need to focus on "Do" not "How to."
07-15-2015 09:22 AM
Nice point guys.
Bring your A-Game:
- KNOW the Tools> Options Dialog inside and out
- Remember your customizations to the Design Patterns (You DO use File: New... exclusively right, Don't tell me you use File>New VI except for sandbox code)
It is important to note that you have to arrive before the exam time to set up the environment!
07-15-2015 10:44 AM - edited 07-15-2015 10:48 AM
Thanks for leading the effort on this Jeff! I'm attaching a presentation we gave at the Minneapolis User Group Meeting a while back with background and exam prep tips for the CLD which should be useful in understanding the scope of the test.
To add onto the benefits of the CLD Jeff mentioned, as an NI Field Engineer, I work with plenty of managers looking for qualified LabVIEW developers. Having a CLD is great for job security, and if you're looking for work, you can effectively pick where you want to be. Even if they don't have a job officially open, they'll often make exceptions if a "free agent" CLD comes along.
<edit>forgot presentation
01-25-2016 05:43 PM
I've got a couple of nitpicky questions.
Thanks for your help!
01-26-2016 07:27 AM
When I took it 15 months ago or so a project was not provided, just a main VI. I did make a project and I think I just used auto populating folders. I would not rename the main VI if I were you, it is possible that they used the VI name for some scanning process.
I think the wire labels comment goes along the lines of making sure you document properly. For me wire labels are rarely used, like maybe once or twice in a large project, but the most comment time I see them used is on block diagrams that are reallllllly wide and you may have wires stretched a long ways and adding a label can help. Another might be if you perform some complicated math function and the output is used some where, you could label the wire of the output if it wasn't going to an indicator. Just some way of identifying the data. My CLD, and CLA had no wire labels.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-26-2016 09:48 AM - edited 01-26-2016 09:56 AM
"Hooovahh" is correct. I'll expand.
You can use a project but this is optional. Just keep the folder hierarchy in place within your project, use the folders (controls & subVIs in respective folders), and most importantly don't change names of provided controls and VI (main panel you'll use to build your main VI). These requirement help us keep the grading process consistent and efficient. Please help us help you!
For Documentation on the exam, we use the VI analyzer to verify that you know how to use the tools. As you program (leading up to your exam), get in the habit of labling wires as you go along in places where it will help you keep track of the data flow. This will develop a good habit so you won't have to think about labelling wires during your exam.
Best of luck as you prepare!
01-26-2016 09:58 AM
Thank you both, I think my question about renaming VIs was not clear. I do want the grader to have a VI with the same name they gave me, I was just wondering if the following was acceptable to get started quickly with a template:
Alternatively, I could probably just copy the block diagram from "Main.vi" to "ATM.vi" and then delete "Main.vi".
01-26-2016 10:02 AM
I have one new question as well. Is it the same vesion of LabVIEW for all tests, or do I have to ask my proctor ahead of time what version it will be? Is the installed version just as if I had freshly installed LabVIEW on my computer? I make heavy use of the "remove" and "insert" quick drop commands.
01-26-2016 10:14 AM
I think these many questions might be better suited in a new thread. That being said I think the answer is, as long as the original front panel is used, and the original VI name is used, it shouldn't matter. The latest version of LabVIEW is used so 2015, that's what I had on my CLA a few months back. It will probably have several NI toolkits installed since these machines have a standard image that is also used for various training sessions.
@MrEF if you work for NI I'd suggest getting the blue member status above your avatar.
01-26-2016 10:16 AM
Should work. Basically we will "point" our grading process towards the VI that matches the name we sent out.
