NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
GPeople
CLD-R sample exam #2, question #11
[ Edited ]
Question #11
Answer A is the stated correct answer according to the sample exam answers section.
Correct me if I am wrong but Merge Errors ONLY reports the FIRST error.  If multiple errors occur with those four error lines,
ONLY one will be reported by error out, not ALL errors.
Where I am going wrong with this one...is it because only one input to Merge Errors is used?
(the error out line looks like a non-array input (thus how could all errors be reported without and array of error outs???)
Ryan
Certified LabVIEW Developer
LabVIEW 7.1 - Present
Trusted Enthusiast
crossrulz
Re: CLD-R sample exam #2, question #11
Yes, this is a tricky one.  You are correct that only one error can be reported.  But sometimes you just have to select the "best" answer.
b and c are out since an error in one write will cause downstream writes to not happen (breaks reliability).
d does not allow for a specific sequence.
Therefore a is all that's left.
Kudos always welcome for helpful posts...Kudos always welcome for any post.
Proven Zealot
Jeff·Þ·Bohrer
[ Edited ]
Exploring "Select the most correct."  you have two requirements.
[REQSHTDN001] Make three values F
[REQSHTDN002] Report all errors
A. and D are the only ones that meat any and are equally correct.
[REQSHTDN003] turn of values in sequence
Might be implied by the provided "Correct" answer but, cannot be determined for the available information.  Therefore, It is a bad question.
I know NI is invested in these types of improvements please, stand by
"All shall be well and all shall be well and all manner of things shall be well" -Julian
Trusted Enthusiast
falkpl
I agree with Jeff, are we to just assume that a specific order is to improve reliability.  This just makes it more repeatable not reliable.  I am reviewing for my recert and was bothered by this question.
Paul Falkenstein
Coleman Technologies Inc.
CLD, CPI
Labview 4.0- 2011, RT, Vision, FPGA
Member
GPeople
How is any answer that is only 50% correct "The Best Answer"?????
It is flat out a bad question and needs to be revised or removed!!
NI needs to step up and provide testing that tests knowledge not obscure trick questions.
Really.
Trusted Enthusiast
crossrulz
Believe me, NI knows.  They are making strides.  Their main problem is a lack of good questions.  If you think you can come up with better questions, try enrolling in the Certification Rewards Program.  Do so by joining the community group and then sending an email to Zaki saying you accept the terms and get writing those questions.
Member
GPeople
I have requested to participate in the Certification Rewards Program....
I will try to come up with 3 -5 variations of this question that are 100% accurate and are nonambiguous.
Thanks!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
