03-23-2016 03:13 PM
Hello all,
This is my first shot at a CLD practice exam. Any (friendly!) feedback would be appreciated. I know there are a couple of functional problems, but most of it works. I would do several things differently, in hindsight, but this is what I got at 4 hours.
Thanks.
Dan
03-24-2016 01:35 PM
Could you save for 2014 or earlier?
03-24-2016 02:04 PM
By all means.
Dan
03-24-2016 03:01 PM
I did not try the ATM example when I prepared for the CLD (nor have I received my score from the test over a month ago yet!) so take my comments with a grain of salt.
Good:
Bad:
Overall, I think that some of what I saw as mistakes will be handled by doing a couple more tests and getting your speed up. You may want to try to go back and remove those extra while loops now and get the Deposit and Withdraw functionality working.
03-24-2016 03:24 PM
Thank you for the feedback. I will definitely try to implement your suggestions in my second attempt at the ATM. I've also taken a look at the solution, and will borrow a few ideas from it as well. How do you feel this attempt would rate on NI's 70% to pass scale?
Thanks again,
Dan
03-24-2016 03:36 PM
I have not actually seen one of their grading reports yet, so I cannot say!
03-29-2016 09:39 AM
@DanRen_IQA wrote:Thank you for the feedback. I will definitely try to implement your suggestions in my second attempt at the ATM. I've also taken a look at the solution, and will borrow a few ideas from it as well. How do you feel this attempt would rate on NI's 70% to pass scale?
Thanks again,
Dan
Run it through VIA and see what it says.
