01-03-2013 05:06 PM
I got the result for my CLA. I didn't pass, but hopefull I will learn from it and do better next time. One comment that I got was "VI properties not documented". I put a requirement tag inside all VI properites at least. Is that not enough? I looked at the ATM CLA sample test, and I saw that many VI only has a requirement tag in their VI proerties, so I thought it is adequate. What is the offical say on that?
05-24-2013 10:16 AM
Bump.
I was wondering about how much VI documentation is required as well.
05-24-2013 12:08 PM
I can't say officially what the rule is. But my opinion is that you HAVE to put the requirement in there and you SHOULD also put in a quick description about what the VI should do. Then comment the heck out of the block diagram so that any fool can figure out what they need to do.
05-24-2013 12:48 PM
I suspect that you might have had a few vi's that need non-default vi properties like "This Dialog shall be Modal" or "This vi shall be re-enterant and inlined"
But that is mainly a guess- I can't see your test.
