10-16-2015 06:42 AM - edited 10-16-2015 06:49 AM
Recently I'm trying to get my CLA.
I pratice those two examples several times.
And I'm still not very sure wherther I'm doing the right way or not.
It's very appreciate leave some comments or suggetsions to me.
1. I've make those practices around 3 hours, is that fast enough?
(I practiced several times, so I barely analyzed, just directly coding. And....when I took my CLD, lots things slow me down, like neverous, strong AC, misunderstanding questions....etc, I think they'll come to me again in the real CLA exam)
2. Did I leave proper comments and messages in the case for developers? (which is the examiner)
I'm not sure did I explain my though clear enough to developers.
3.The prep guide said it's important to build a timing module, which is I didn't , instead, I encapsulate "local timer" into the
class.Is that acceptable for NI ? (In the real world, I use this method very often,if I only use this in single loop, so I don't need extra FGV to confuse me in the project)
4.Like the third point, I didn't build the data base module, I directly encapsulate into the Ancetor.lvlcass and make it as public data
(every APIs or child classes could access it through property node )
Mabolas
