Certification
CLA ATM Practice Solution, requesting review and comments (OOP solution)
Hi all,
This is my SECOND attempt at the CLA practice exam. Because it was my second attempt, I reduced my time to 3:10 instead of the full 4:00. I figure I'll lose ~45 minutes on the real exam getting acclimated to the problem.
I'm pretty comfortable using Actor Framework for my professional work, so I tried to apply it here. Unfortunately, I think I'm going to need to switch gears... the result feels nowhere near complete. The time crunch is much worse compared to when I did the CLD.
Overall, looking for thoughts on my organizational structure, general recommendations on what I might get dinged for on what IS done, and of course opinions on how far from a "pass" this solution is. I definitely don't consider this a passing solution, but some thoughts on what I should work on would be helpful.
It's in LabVIEW 2012, where Actor Framework is native. If you would like to look at it in a different version of LabVIEW, let me know and I'll try to back-convert.
Thanks.
Mike
(7,576 Views)
Curious how this went? I saw your link to this on Reddit.
I just took the CLA this morning and I used almost identical architecture to the solution from the ATM sample exam. Did you try a new approach last year? How'd it go?
Cheers
(6,896 Views)
I went ahead with Actor Framework on the actual exam. Fortunately, I passed. I was docked on a few things that I found surprising but what ultimately matters is getting the certification, so I can't complain too much.
Hope that you hear back with a positive result! Definitely let me know how it goes.
(6,847 Views)
I passed with a 90%! I used a QMH module architecture just like they use in one of their practice solutions and it worked out for me. 🙂
Cheers
(6,683 Views)
Hi, Would you please mention which sample exam solution you have used? and have you used the template message library of QMH?
(3,608 Views)
