NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
apok
Any Help/Direction in preparation for CLD
Hi ALL,
I've done my research on all information in this forum on CLD...it seems to be the elusive "Golden Egg" I can't find much of? I've done the "boiler,sprinkler,atm,  and carwash" in a couple different syles("producer/consumer and state machines). I've practive the read/write vi's on plain .csv and .txt files to array and array to files. Property Nodes, Array manipulations, Static and Dynamic Events, Mathemactical Algorithms, Queue Notifiers and Operators. I've seen the E-Kit downloads and NI links...
MY question here after mentioning the above information, is there any more functions I need to know other than the sample tests. Can the certified CLD'ers chime in and broaden my awareness on what is not covered in the test examples...Active X, Daqmx, VISA, Filters, Instrument IO's...ect. THANKS!
Active Participant
pallen
Re: Any Help/Direction in preparation for CLD
You won't see Active X, DAQ, VISA, or Intrument IO on the CLD.  I don't recall Filters either.
Sounds like you're practicing the right things.
Patrick Allen
Proven Zealot
Jeff·Þ·Bohrer
:smileywink:Great question!
Your focus seems pretty close:
  • Design Patterns
  • File IO
  • Synchronization
  • Function Palatte familliarity
  • Properties of FP Objects
Are all "Musts" to achieve that passing score on the CLD
Toss in:
  • Timing- you will have a timing requirement.
  • Documentation practice (the cheapest points on the exam in points per time needed)
You, of course, read the style guide too - :smileywink:right?
Next step:  Take your examples and run them through the VI Analizer.  How did they do?  I'll bet $'s to Doughnuts at least one evaluator will do this too
"All shall be well and all shall be well and all manner of things shall be well" -Julian
Active Participant
apok
THANKS for the replies guys!....yes, i forgot to mention timing (I could mathimactically create it from scratch of just use the "elapsed time" function, seems easier to use) . Just a side note: I did talk with Ni on cost ($299USD) as I could not find a price here.
Again, maybe you guys can tell me what concepts probably hung you up on time (other than documentation blah, blah)?:smileywink:
Active Participant
apok
Hint: I thought that bundling an Enum Commands and Varient Data to a cluster through a register, passes state machine commands and whatever data you want to any state condition. I liked that approach during Core 3 training, a nifty way of handling data between states. Another cool trick I learned...using "Sysinternals Screen Magnifier", since it would be too much for NI to do on its own software....I could hardly ever see what I am coding unless on a 60" DLP monitor.:smileyvery-happy:
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
