BreakPoint
What is this and what is it used for
@Wayne.C wrote:
Diamond impregnated tool used to polish slabs of granite/marble.
Winner!
I think this is the closest you guys will get without knowing the industry in which it's used. Not a polisher and not for granite/marble, but very close.
It is a diamond plated tool that is used to grind glass. We use it in conjunction with our 16ftx16ft 5-axis grinder. This specific tool was created to cut a triangular groove in a quartz block.
Here are some close-ups of the edges:
(This iPhone camera continues to suprise me.)
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 41 of 294
(9,696 Views)
Thank you James for the adventure and the lesson. If I remember I'll take some pictures for another round next week.
Ben
Message 42 of 294
(9,678 Views)
I was distracted by these...
...and completely forgot to hunt for and take pictures.
Ben
Message 43 of 294
(9,599 Views)
Ben:
That one is too easy, potatoes, and they are used to launch out of a spud cannon as projectiles.
-AK2DM
Message 44 of 294
(9,576 Views)
I take fries with that. 😄
Message 45 of 294
(9,572 Views)
Just butter and cheese for me, after it has been properly baked.
GCentral
Message 46 of 294
(9,564 Views)
For a start I will just share these in the order I took the pictures. I suspect we all use the name sake of this item but it is the special form that amkes this item unique. Higly recomended for college students these days.
Front side with a dime to show the size.
Bottom side
 Weights in at about 3-4 lbs.
It is the special use that makes this item special.
Ben
Message 47 of 294
(9,521 Views)
Bullet proof?  (OMG, theese preppers :D)
The surface structure migth aid to make 'straight' hand drawn lines ....   well, ...  horizontal/vertical and maybe even 45° ones
My first thougth was honeycomp  for a beehive, then I had a close look ....
Greetings from Germany
Henrik
LV since v3.1
Message 48 of 294
(9,514 Views)
OK that lasted a whole 23 minutes.
Here is one that I do NOT know exactly what it is. Maybe you can tell me. I found it in a dumpster.
The right end has a aluminum disk glue to it with a 3/4 inch hole drilled in it.
If you know plese tell me!
Ben
Message 49 of 294
(9,508 Views)
A flux resistor! The sister component to the flux capacitor.
Cheers
Message 50 of 294
(9,510 Views)
