BreakPoint
What is this and what is it used for
@crossrulz wrote:
@ThiCop wrote:
A tip:
The hat itself contains objects that become visible by pulling the rabbit out of the hat.
Sounds like a gum ball machine
Spoiler
that was the clue I needed to set Google loose.
Ben
Message 21 of 294
(9,721 Views)
Nope,
The objects that show up are not considered to be food.
You can consider them as eating utensils.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 22 of 294
(9,705 Views)
If it's that small, it can only be one thing!
Spoiler
It's a toothpick holder/dispenser
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 23 of 294
(9,686 Views)
Kind Regards,
Message 24 of 294
(9,680 Views)
Sweet!
Alright next one:
Cheers
Message 25 of 294
(9,672 Views)
Engine valve
PaulG.
LabVIEW versions 5.0 - 2020
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 26 of 294
(9,654 Views)
Nope. Hint:
Spoiler
It doesn't go inside of anything. You can see it during use.
Cheers
Message 27 of 294
(9,637 Views)
Again a question of its size....
door stopper? 🙂
Norbert
Norbert
Expert: Geometry
Message 28 of 294
(9,636 Views)
It is used to make round things like turning blobs of glass into marbles or steel into ball bearings?
Ben
Message 29 of 294
(9,633 Views)
Smiley Very Happy Anything can be used as a door stopper.
Spoiler
The circular part is 6 inches diameter.
Not used to make ball bearings, but on a side note that process is pretty cool. They just tumble the balls through specific sized grooves and this breaks off all the edges until you get the prefectly round balls. This explains it well.
Cheers
Message 30 of 294
(9,624 Views)
