01-15-2010 12:37 PM
Hi!
I have a background in EE, and this is a subject that my schooling did not teach me very well (sadly). I've reviewed ASME PTC 19.1-2005 "Test Uncertainty" and some of it was really helpful and good but a lot of it felt like it was over my head. None of the examples provided were simple, and I felt like they were overly complicated.
I need a good reference for how to get from Point A - knowing the independent accuracies of my instruments, to Point B - knowing the accuracy of a particular number in a data file.
I feel like I've gotten a grip on correcting systematic errors in my measurement process. For instance, we have standard calibrated pressure transducers of various ranges that we use.
It is the random errors that I have a hard time working with. I just have so many questions that it is difficult to outline them all here. So I'm after a good reference that defines the measurement process, defines how to measure (or calculating) the error of that measurement process, and the standard ways of reporting this error.
If anyone can recommend some good reference I would greatly appreciate it. I have a stack of standards, but I need something on the introductory level before I feel like I can start applying the standards to my practice.
Thank you for your input.
-nic
01-15-2010 01:13 PM
01-25-2010 03:44 AM
GUM: Guide to the Expression of Uncertainty in Measurement
Starting point:http://en.wikipedia.org/wiki/Measurement_uncertainty
and digg in the external links....
For the beginner http://resource.npl.co.uk/cgi-bin/goto_pubdb.pl?rec=2284
Just found some software @ NPL here (there is also a LabVIEW simulation for a LockIn Amp ...)
12-05-2013 03:01 PM
Hi
I interested in the subject..
Do you have more advance guidance about uncertanity measurement or reasoning for uncertanity in test and measurement systems etc.
Kind regards,
Faisal Azeem
12-06-2013 02:19 AM - edited 12-06-2013 02:26 AM
We used to recommend this book as an introduction to data and error analysis in experimental work:
http://www.amazon.co.uk/Experimental-Methods-Introduction-Analysis-Presentation/dp/0471335797
It gives pretty decent reasoning for the various approaches used.
12-06-2013 03:44 AM
@Agha wrote:
Hi
Kind regards,
Faisal Azeem
Try the GUM
or
http://www.nist.gov/itl/sed/gsg/upload/TutorialMetrologists2011Nov22.pdf
(Work through the references and you can call yourself an expert)
