08-13-2013 04:34 PM
Just had a chance to install a distributed exe on a Surface Pro. Very slick, so far. Several copies of logic and UI for duplicate controlled motion and sensors. Simple DAQ, this time (USB-6009), and USB-to-Ethernet adapter for UDP. Haven't seen MAX, yet, but someone here was running the LV2012 IDE with USB DAQ (of course an external monitor and a mouse helped a lot.)
Not to try a LV2013 app and see if a control with key focus will change value with a two-finger swipe (mouse scroll).
Disclaimer: I am not a Microsoft employee, but I have done work for them.
03-11-2014 11:38 AM
I'm trying to use the USB-6009 through Ethernet with a USB over IP adapter (http://www.startech.com/Networking-IO/USB-PS2/10-100-1000-Mbps-Gigabit-1-Port-USB-over-IP-Device-Ser... but NI Max doen't find the device. It does it if it is directly connected through the USB port. You mention a "USB-to-Ethernet adapter for UDP" that you are using. Have you had any success with it? If yes, please, could you recommend me which device you used?
Many thanks,
Alex
03-12-2014 06:05 AM
I believe I have my answer on the following NI forum:
I'll keep looking for an alternative then...
