NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Trusted Enthusiast
SteveChandler
Re: The Boneheaded Code Thread
Kudos Ben! That is the spirit I had in mind for this thread. If this were a book a good title might be "Brave Confessions of the Brain Dead Software Engineer"
Let's keep 'em coming!
LabVIEW 2012
Proven Zealot
Jeff·Þ·Bohrer
[ Edited ]
OK I'll play too.
Task: Jeff quick set up a vi to cycle a temperature chamber up and down all night with this recording device in the chamber.  We want to make sure these production prototypes do what they are supposed to do (Shut off when either too hot or too cold).  You have 30 Minutes to set up.
Here is a simplified recreation.
Spoiler
We learned the plastic melts at 137C
Spoiler
Spoiler
The AND is bad!!! shouldn't that be an OR?
I've since learned how to use In Range And Coerce
"All shall be well and all shall be well and all manner of things shall be well" -Julian
Member
drjdpowell
I must have had a hundred bugs that were due to me reversing the True and False cases, or using Less Than when I should have used Greater Than.  Almost seems like I do it wrong more than 50% of the time.
Trusted Enthusiast
crossrulz
Yeah, I've been there Jeff.  My recent boneheaded mistake was checking to see if an element want found in an array (Search 1D Array) and set the comparison to >0.  It took me awhile before I realized that it's >=0.
Kudos always welcome for helpful posts...Kudos always welcome for any post.
Active Participant
SnowMule
They're like USB connectors.  50% chance of getting it in the right way the first time, and 80% of the time you get it wrong.
Active Participant
DianeS
Odd...I find that if I have a 50% chance of getting it right, I have a 100% chance of getting it wrong.
SnowMule is either smarter or luckier than I am.  :smileyvery-happy:
Active Participant
Thoric
Also, you're not subtracting the step from the previous value, but the previous value from the step? This means on the first attempt to reverse direction you end up with a negative temperature (once you fix the boolean logic error)?
Thoric (Certified LabVIEW Architect and LabVIEW Champion)
Proven Zealot
Jeff·Þ·Bohrer
go figure! recreate a bonehead mistake and make another! :smileyembarrassed:
Trusted Enthusiast
for(imstuck)
[ Edited ]
In benckmarking code, why the @#$@#$!#$!#$!#$!#$!#$ won't my two sums come out the same do my two sums SOMETIMES come out the same:headbang:
Greg Freeman - CLA, LV Version 2012, 2011, and 2010
G Systems, LP
Knight of NI
altenbach
Just looking at the picture, they will be the same if you have fewer than 256 matches. :smileyvery-happy:
LabVIEW Champion . Oh, by the way, I work for peanutsKudos .
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
