BreakPoint
The Boneheaded Code Thread
Kudos Ben! That is the spirit I had in mind for this thread. If this were a book a good title might be "Brave Confessions of the Brain Dead Software Engineer"
Let's keep 'em coming!
LabVIEW 2012
Message 11 of 21
(11,160 Views)
OK I'll play too.
Task: Jeff quick set up a vi to cycle a temperature chamber up and down all night with this recording device in the chamber.  We want to make sure these production prototypes do what they are supposed to do (Shut off when either too hot or too cold).  You have 30 Minutes to set up.
Here is a simplified recreation.
Spoiler
We learned the plastic melts at 137C
Spoiler
Spoiler
The AND is bad!!! shouldn't that be an OR?
I've since learned how to use In Range And Coerce
"Should be" isn't "Is" -Jay
Message 12 of 21
(11,129 Views)
I must have had a hundred bugs that were due to me reversing the True and False cases, or using Less Than when I should have used Greater Than.  Almost seems like I do it wrong more than 50% of the time.
Message 13 of 21
(11,114 Views)
Yeah, I've been there Jeff.  My recent boneheaded mistake was checking to see if an element want found in an array (Search 1D Array) and set the comparison to >0.  It took me awhile before I realized that it's >=0.
GCentral
Message 14 of 21
(11,072 Views)
They're like USB connectors.  50% chance of getting it in the right way the first time, and 80% of the time you get it wrong.
Message 15 of 21
(11,061 Views)
Odd...I find that if I have a 50% chance of getting it right, I have a 100% chance of getting it wrong.
SnowMule is either smarter or luckier than I am.  Smiley Very Happy
Message 16 of 21
(11,051 Views)
Also, you're not subtracting the step from the previous value, but the previous value from the step? This means on the first attempt to reverse direction you end up with a negative temperature (once you fix the boolean logic error)?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 17 of 21
(11,020 Views)
go figure! recreate a bonehead mistake and make another! Smiley Embarassed
Message 18 of 21
(11,018 Views)
In benckmarking code, why the @#$@#$!#$!#$!#$!#$!#$ won't my two sums come out the same do my two sums SOMETIMES come out the same:headbang:
Message 19 of 21
(10,957 Views)
Just looking at the picture, they will be the same if you have fewer than 256 matches. 😄
Message 20 of 21
(10,948 Views)
