NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
ShotSimon
Re: Simple LabVIEW Puzzle Challenge
Ravens Fan wrote:
Which were you thinking of as the challenge, LV program to solve and finding the solution?  Or a LV program as a game to help a person to discover the solution.?
Either would be acceptable, but the game sounds like it would take longer.  -SS
Trusted Enthusiast
Darren
[ Edited ]
Ok, I'll go first.  Here's a brute force approach that discovers the optimal time very quickly.  Theoretically this approach could take an extremely long time if the random pulls are infinitely unlucky.  I'm guessing some math whiz could come up with a better way to pre-calculate all the possible combinations and just run through those.
Here's a screenshot of the diagram, and the VI (saved in LabVIEW 7.0) is attached below.
-D
P.S. - GAMES magazine is awesome!  My favorite puzzles are Cryptic Crosswords and Cartoon Rebuses.
Message Edited by Darren on 09-09-2008 12:19 PM
Darren Nattinger, CLA
LabVIEW Artisan and Nugget Penman
Active Participant
ShotSimon
Darren,
Excellent! I love the icon:smileyvery-happy:  -SS
Active Participant
ShotSimon
Darren,
After further review I realize your solution doesn't actually provide or show the order of who went where and when:smileytongue:
But it's still the only attempt so far.  -SS
Trusted Enthusiast
Darren
[ Edited ]
Easy enough to add...the data was on the diagram, just needed to add it to the panel:
-D
Message Edited by Darren on 09-09-2008 04:43 PM
Active Participant
ShotSimon
[ Edited ]
Darren,
Looks like you're the only one to take the challenge.  I really like your very simple brute force approach.  When I solved the problem I got it stuck in my head to use toggling back and forth between moving two over and one back.  I was playing around with logical checks such as 5 & 10 must go together but gave up since it made the vi very complicated.
I plan on creating another solution that generates all possible solutions as you suggested.
Here is my solution, FYI you solved the puzzle much faster than I did using LabVIEW very impressive.
I will post a new puzzle shortly.  -SS
Message Edited by ShotSimon on 09-10-2008 09:33 AM
Active Participant
ShotSimon
[ Edited ]
OK LabVIEW puzzle #2 is more challenging and is known as a magic star.  I will provide the start to one solution but would like to see someone solve for all solutions.
The rules are similar to a magic square.  Using the integers 1-12, each only once, complete the magic star such that each line of four number's sum is equal to the same number 26.
Since this is a harder puzzle I may post a new puzzle before this one is completely solved by someone.
-SS
Message Edited by ShotSimon on 09-10-2008 10:49 AM
Trusted Enthusiast
Darren
[ Edited ]
Here's my solution for the Magic Star.  It generated 960 solutions.  Since there are over 479 million combinations of the numbers 1-12 in the star, it took this VI a couple of hours to run.  Again, I used a brute force approach, but this time I was able to calculate every single possible combination (compared to the random combinations I used in the Bridge Crossing problem).  Also, credit partially goes to a permutation VI I found at http://www.fafiles.com/examplevis.php that I used as inspiration in calculating my permutations.
The VI is saved in LabVIEW 8.5 this time, since I used For Loop with Break in my solution.
-D
Message Edited by Darren on 09-10-2008 03:02 PM
Active Participant
ShotSimon
Darren,
That is amazing and very well done.  My guess is you are a puzzle master.
I've decided to leave Puzzle #3 open for you to choose...since I can't give away prizes:smileyvery-happy:
Try to keep the level of difficultly between LabVIEW Puzzle #1 and Puzzle #2.  -SS
Active Participant
ShotSimon
[ Edited ]
Darren,
This is known as a magic star order 6 and has 80 solutions.  I think the 960 comes about if you count rotated solutions as different solutions, so you are correct.
It is interesting to note some people solve all 80 with paper and pencil using logic no programming.  -SS
Message Edited by ShotSimon on 09-10-2008 04:25 PM
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
