02-16-2015 08:19 PM
@thoult wrote:
@tst wrote:
@Ben wrote:
After asking 8 LV developers, 6 of which are CLA's NONE of us knew that.
By now I'm so used to LV's widespread polymorphism with certain types of functions, that I'm usually only surprised when I try something like this and it doesn't work.
This. I also get irrationally annoyed when it's not!
Yep me too. Even some (what I think should be) fairly trivial functions don't let me bung arrays into them (can't recall any off hand though). Makes things nice and messy for me.
03-05-2015 08:25 PM - edited 03-05-2015 08:25 PM
Seen here.
03-06-2015 11:01 AM - edited 03-06-2015 11:03 AM
If the array is twice as long as it should be, we would typically use the array subset function.
Apparently, there are better ways (if you are paid by the diagram area and raw amount of code). 😄
There are quite a few RG elements. Can you find them all?
03-06-2015 11:07 AM
Actually, that would be a Decimate 1D Array (they ar keeping every other element).
03-06-2015 11:17 AM
Yes, you are possibly right. However, a decimation would be incorrect for the convolution problem at hand. He needs to take the array subset.
I thought maybe the wire is actually connected to the IQ terminal (with some wire bends under the node), which could easily be the case judging from the mess of the other wires. 😄
03-09-2015 02:13 PM - edited 03-09-2015 02:16 PM
That wouldn't halve the array size (unless N=4) So the thing is both RG Rich and fails to meet requirements (OOPS- That happens with "Richly Obfuscated" code)
How did I do?
Edit - I nearly did the "coffee forcefully expelled to monitor" thing when I read your response "You probably should have had a coffee and waited for the second thing"
03-13-2015 02:29 PM - edited 03-13-2015 02:37 PM
Saw this one today.
I suppose it's possible the author could be forgiven since this was originally written in 1999. That's before my time - does anyone know if the Delete From Array primitive did not exist by that time?
03-13-2015 03:00 PM - edited 03-13-2015 03:21 PM
I am pretty sure that "insert into array" and "delete from array" are relatively late addition to the array palette. (The matrix things are even newer.)
Edit: Yes, I was right. Just checked my LabVIEW 4.0 installation and it does not have the insert/delete function in the array palette.
03-16-2015 05:22 AM
You have a LabVIEW 4 installation?! o.O
/Y
03-16-2015 07:13 AM
@Yamaeda wrote:
You have a LabVIEW 4 installation?! o.O/Y
Don't look so surprised. He also has a copy of LabVIEW 3.
