12-09-2014 11:58 AM
The comparison mode is set to compare aggregates in this situation. Which would give a scalar out
12-10-2014 07:28 AM
@Todd_Lesher wrote:
Compare elements would have a 2d wire coming out instead of a scalar.
Of course. Doh! My bad.
12-25-2014 10:26 AM - edited 12-25-2014 10:33 AM
Apparently, casting a U8 array to a string requires a FOR loop, shift register, typecast and concatenate operation and at least 9 wire bends. Why??
02-09-2015 08:17 AM
I am teaching a few friends some basic programming in LabVIEW. Before starting a discussion on standard LabVIEW design patterns, I thought it would be useful for them to try a simple program without proper design. I had them build a simple calculator that would either add, subtract, multiply, or divide two numbers. Here was my favorite result:
02-10-2015 07:32 AM - edited 02-10-2015 07:33 AM
That Can't be a Rube as a Rube is meant to at least function correctly. The behaviour of the event structure means that that will never execute as the designer hoped, although it is interesing to see how they were thinking!
02-10-2015 09:57 AM
It runs. And it even works. Both ES fire on value change.
02-10-2015 12:13 PM
For now. But having two event structures in the same loop is a disaster waiting to happen.
02-10-2015 02:02 PM
I didn't say it was good design practice; I said it worked.
02-10-2015 06:36 PM
The second event structure does almost nothing and really can be removed. the RB code is how he did the math...
02-10-2015 06:36 PM - edited 02-10-2015 06:37 PM
How is it that every other forum in existance has figured out how to prevent double posts...? 😞
