NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
Andrey_Dmitriev
Re: Rube Goldberg Code
Ben wrote:
 - c'mon Christian, show us the REAL solution that uses only 2 base functions!!! - you know you want to:smileywink:
You're right, but it wasn't specified overall amount used functions. My solution uses also only two base functions, but multiple times. Just created another example of "Rube Goldberg Code" :smileylol:
Active Participant
Hornless.Rhino
SnowMule wrote:
Shouldbe easy enough to clean up with a screen thisbig. :smileyvery-happy:
Just use block diagram cleanup and hope for the best :smileytongue:
Active Participant
J.Mamakos
[ Edited ]
This, this library makes me want to cry every time I open it!  I was given it not so long ago, accompanied by a jovial request to "simply update this to LabVIEW 8.5 and fix any bugs you find".  If you ever start to feel too relaxed, I hope this will help to reinstate your stress levels to the hights that they should normally be. :smileyhappy:
A few pictures to tickle your taste buds:
Spoiler
Never say "Oops." Always say "Ah, interesting!"
Currently migrating/rewriting code from LabVIEW 6.1 to 8.5
Member
PiDi
Some time ago, in some spaghetti-horror code, I've stumbled upon following chunk:
Yeah, why using new value when old one is the same? :smileyvery-happy:
Active Participant
Hornless.Rhino
Maybe they wanted a time delay
Knight of NI
Ray.R
[ Edited ]
Saw this in code I am working on.  I'll be able to tease the author..  LOL!
top: original
bottom non-RG
(starting to) See Life in a brand new way...
b* ^ )
Proven Zealot
Hi Ray,
well, you could omit the GetDateTime function too as FormatDateTimeString already uses current time as default input...
CLAD, using 2009SP1 + LV2011SP1 on WinXP+Win7+cRIO
Kudos are welcome :smileywink:
Knight of NI
Ray.R
That's true..  :smileyhappy:  I RG'ed myself
b* ^ )
Trusted Enthusiast
LV_Pro
It was probably done in one of the 5 min. updates before a demo! Or  - my brain ws fried from looking at someone's "regular expressions" (why they are called "regular", sort of like "common sense", an oxymoron!)
Putnam Monroe
Certified LabVIEW Developer
Senior Test Engineer
Currently using LV 6.1-LabVIEW 2012, RT8.5
LabVIEW Champion
Knight of NI
Ray.R
[ Edited ]
LOL!!  Glad you like regEx :smileyvery-happy:  I might be able to squeeze a few more in there.
Check your PM...  I'll give you an update since last week.
Now my turn to check for Rube...
Is the following code a Rube?  For some reason, I seem to think there is a better way to get a string of a 4 digit number...
Ah crap..  I just thought of it...  Using a regEx, of course...  I'll post the Rube code anyway..
b* ^ )
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
