NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Knight of NI
altenbach
Solving a 3x3 linear system of equations
[ Edited ]
To solve a 3x3 system of linear equations takes an...
  • 18 frame sequence
  • 48 local variables
  • 18 sequence locals.
Then we need to run it in "continuous mode" and press the button for each recalculation.
Somehow, I don't want to see the code to solve the 10x10 case!!! :smileysurprised:
Message Edited by altenbach on 10-30-2007 11:09 AM
LabVIEW Champion . Oh, by the way, I work for peanutsKudos .
Trusted Enthusiast
chilly charly
Re : Rube Goldberg Code
[ Edited ]
A classic one ?
What's less classic is that this piece of code was produced by an application engineer at NI :smileysurprised:
This being said, the LabVIEW Text-To-Speech example was great  !
Message Edité par chilly charly le 11-01-2007 06:26 AM
Chilly Charly    (aka CC)
         E-List Master - Kudos glutton - Press the yellow button on the left...
Knight of NI
altenbach
Re: Re : Rube Goldberg Code
Of course this needs to be done every 10ms while the program is not really doing anything useful. :smileyvery-happy:
I agree, Pretty cool! :smileyhappy:
It does not work correctly on my PC under LabVIEW 8.5. The step 2 property node generates an error because the "disable items" receives a "-1". Thus the "devices" field remains empty. The "get audio devices" does not properly propagate the error, but actually clears the error without returning any devices. To fix this, the error cluster in the FOR loop (inside "get audio devices") needs to use a shift register. (A FOR loop with zero iterations returns the default data (no error!) on an output tunnel, but would returns the input value on a shift register).
It works fine if I simply delete the error wire going into the "get audio devices".
Trusted Enthusiast
chilly charly
Re : Re: Re : Rube Goldberg Code
[ Edited ]
On my MacBook Pro (running LV 8.5 under WinXP with Fusion from VMware...), I had no problem, except the first run, when I forgot to select explicitely the only audiocard emulated on my machine. So nothing to remove, nothing to change (I even left the beautifull piece of code that I reproduced in the last post !):smileyvery-happy:
Message Edité par chilly charly le 11-01-2007 08:17 AM
Active Participant
shoneill
CC,
firstly, I'm happy to see you taking a more active role in the forums again.  Welcome back!
There have been quite a few pieces of code posted in this thread with a boolean constant wired to some kinf of "If true then.." structure.
I have to admit that I'm sometimes guilty of that too.  During programming, it's occasionally not quite clear which "polarity" the signals should have to produce the required effect in a given situation.  This is a (quick and dirty) way to allow a quick "swapping" of the polarity if it's found to be wrong in the first place.
Of course one could argue that it should be found out once and replaced with a simple boolean constant, but sometimes the time is too short for such niceties.
My name is Shane, And I'm a Goldberger. >Phew< I feel kind of relieved to get that off my chest....... :smileytongue:
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Knight of NI
Ray.R
LOL!!  We'll have to start the Goldberger Anonymous  Wireworkers (GAW) thread!  :smileyvery-happy:
(starting to) See Life in a brand new way...
b* ^ )
Active Participant
craigc
Re: Rube Goldberg Code
My Name is Craig and im a goldberger, i have stayed clear of array size wiring of for loops and I have now been using auto indexing as a substitute for over 6 months! :smileyvery-happy:
LabVIEW 2009 .
DTA
Trusted Enthusiast
TCPlomp
Hi Greg
My LabVIEW Ideas
Knight of NI
altenbach
[ Edited ]
Here's a way to do some hex formatting on a simple number. Of course it does not produce the desired result, but that's a side issue. At least this will scale very well to multicore CPUs because of all the duplicate parallel data paths. :smileysurprised: (just kidding!).
Message Edited by altenbach on 11-16-2007 10:16 AM
Trusted Enthusiast
chilly charly
[ Edited ]
I think I could win a prize with this one :
The conversion of a series of 60 chars received on a serial port could be done with the following code,
but was attempted with the code below. Of course it didn't work...
Adapted from this thread
Message Edité par chilly charly le 11-19-2007 04:39 PM
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
