10-31-2014 09:01 AM
@parthabe wrote:
Today's delight! 🙂
Stern Warning! When there is no error from the H/W, you should be extra careful with the way you code. 😉
The case structure only looks at the boolean part of the error cluster. If the wire has a warning (false + error code), this code will reset it.
I don't know if that's the actual intended case, though.
10-31-2014 09:02 AM - edited 10-31-2014 09:02 AM
@parthabe wrote:
Today's delight! 🙂
Maybe if things work properly then warnings will be generated, and you want to clear it?
EDIT: Beat again.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-31-2014 10:25 AM - edited 10-31-2014 10:26 AM
Edited: Ignore Post, didn't read the next page... 🙂
10-31-2014 11:38 AM - edited 10-31-2014 11:41 AM
But that's why we have the "clear errors" primitive.
No need for case structures, tunnels, selectors, diagram constants, etc. (Well, they are still all there, just inside a system VI :D)
10-31-2014 11:50 AM - edited 10-31-2014 11:51 AM
I think the clear specific error primitive is very recent... I don't have it, and I'm running LV 2012.
(I acutally do have a clear specific error vi in my user library, and have always wondered why NI didn't have it included themselves... )
Without the new primitive, the shown way does seem to be a fast and clean method to remove the warnings.
10-31-2014 11:57 AM
But you have the clear all errors (same, but without the upper input), which is similar to what is discussed here.
Personally I would probably have left out the diagram constant and used a "use default if unwired" output tunnel. 😉
10-31-2014 12:33 PM - edited 10-31-2014 12:34 PM
AFAIK, there is no Clear Specific Errors VI. There is only a Clear Errors VI, and it is available in LV 2011 also.
10-31-2014 01:18 PM
Yup Clear Errors has existed since at least 2011. Clear errors selectivly exists in 2014 nativly. Of course OpenG and MGI have had their own versions of filtering errors for a while.
10-31-2014 02:17 PM
It is there in 8.5 also. If I remember correctly, it was there in 7.x as well.
10-31-2014 02:35 PM
Looks like it was introduced in 7.0. 🙂
http://labviewwiki.org/Error_handling
