04-26-2012 04:17 PM
My turn at creating a RG code...
That's what happens when you try to do something quickly..
original code:
improved:
Yes... yes, I am aware of the coersion dots... ![]()
04-27-2012 02:54 AM
Well, it could be simplified further - you're taking the 1D array of RGB values and then turning it into 3 2D arrays of RGB values and then making that into a 3D array.
So you could move the build array to be after the decimate and then do the reshape in a loop.
Or you could use the picture VI which converts a flattened pixmap to a 2D U32 array and then use split number on that array to extract the RGB arrays.
05-15-2012 01:04 PM - edited 05-15-2012 01:15 PM
Some code can only be described as tapeworms: ugly, unwanted, and hard to get rid of.
07-28-2012 12:44 PM - edited 07-28-2012 12:47 PM
Generating a regularly patterned 3D array, then slicing out one of the planes in a given orientation may need a multiscreen sized diagram, case structures with the same property node on all cases, shift registers, empty arrays, intermediary array of 1, 2, 3 dimensions, stacked loops, etc.
(note that the above picture is scaled to 50% of the actual size!).
Or it could all be done with some simple postcard sized code. ![]()
07-30-2012 07:39 AM
I think. when I code some times,no need to purposefully make it as a Rube Goldberg Code,it will naturally turn to a Rube Goldberg Code
Anyway I think Rube Goldberg Code will disappears gradually as experience build up...
07-30-2012 10:35 PM
Either that or you just find more and more nitty-gritty things to optimise.
08-02-2012 01:48 PM
Same thing
08-07-2012 07:16 AM
Same can be easily represented as:
08-07-2012 07:19 AM
In the above code just take few number of bytes and reversing it inside an array.
08-07-2012 07:36 AM
In the above RGC,If the array size is getting bigger and bigger then definitely the first one will become a Rube Goldberg one.![]()
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
