07-03-2009 03:01 AM - edited 07-03-2009 03:03 AM
This is the continuation of the June 2009 bug thread.
The rules are as always:
July bugs everywhere!!!
07-07-2009 01:03 AM
"data entry" settings behave incorrect for numeric controls in LV 8.6.1:
http://forums.ni.com/ni/board/message?board.id=170&message.id=421753&jump=true
07-07-2009 08:12 AM
chrisger wrote:"data entry" settings behave incorrect for numeric controls in LV 8.6.1:
This bug has already been reported LV 8.6.1 Bug in Data Entry Limits for controls and fixed in 8.6.1f1
07-07-2009 08:20 AM - edited 07-07-2009 08:22 AM
See this thread for more description and steps to reproduce.
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=420500#M420500
After changing the Read Lines check mark in the right click menu, the compiler doesn't correctly check the wire types coming out of the VI to the string array indicator or string indicator (depending on which was initially wired up and the new mode set for the VI.)
07-10-2009 10:27 AM
07-14-2009 05:33 PM
07-17-2009 01:46 AM
Matthew Kelton wrote:64 bit ints do not properly show digits in SI mode if rounding needs to occur.
CAR ID #179239
07-17-2009 02:10 PM
As described here, the Read Key (Path) does not return correct path for key values that begin with "\\\\" in a config file.
CAR# 179652
07-21-2009 10:21 AM
IPE structure replacing the wrong element under certain conditions:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=425606#M425606
I haven't checked it myself, so I'm not sure of the details (version, etc.).
07-24-2009 10:33 AM
