09-16-2008 12:05 AM - edited 09-16-2008 12:09 AM
09-18-2008 02:09 AM
09-24-2008 12:30 PM
09-28-2008 05:16 PM - edited 09-28-2008 05:18 PM
Long time issue with conditional disable structure inside unzip.vi, preventing executable build.
09-28-2008 05:34 PM
LV8.6 won't build when code contains boolean constant wired to a case structure.
09-29-2008 01:40 PM - edited 09-29-2008 01:45 PM
Entering a description for a diagram constant via the properties dialog does not stick (LabVIEW 8.6 only, works fine in LabVIEW 8.5.1).
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=358506
10-01-2008 02:47 AM
10-01-2008 03:51 PM
Regarding Ben's entry: Issue with "Bundle" node in LV 8.5
This code can be found on LAVA in this thread.
I've confirmed the issue discussed in the LAVA thread was previously reported to R&D (CAR # 113018) and subsequently fixed in 8.6.
Roy
