10-22-2008 03:42 AM
10-22-2008 04:30 AM
smercurio_fc wrote:
aartjan wrote:A new type of error while Labview crashes.
http://forums.ni.com/ni/board/message?board.id=170&message.id=357011&jump=true#M357011
Aart-Jan
Please note that this thread is to report confirmed bugs, not errors which as of yet have not been confirmed to be actual bugs with LabVIEW. As I noted in my response in that thread, do you have a CAR?
10-22-2008 06:10 AM
10-22-2008 12:10 PM
The "Use Default Limits" text in the properties dialog appears garbled in 8.6 -
http://forums.ni.com/ni/board/message?board.id=170&thread.id=363628
10-23-2008 04:54 AM
When a library (.lvlib) that contains a file with a run-time-menu (.rtm) file is removed from the project, but there is still a file that uses this .rtm file, both the .lvlib and all of it's vis and the .rtm file are displayed in the project Dependencies.
For the Vi's the callers can be found by 'Find->calllers'. For the .rtm file this always results in 'No items found' but the .rtm file remains in the Dependencies (as it should since it is still used).
Finding the .rtm file can be hard since it is only loaded at run-time and not at edit time(?). If someone encounters this issue, a working method:
- rename the rtm file (so it cannot be found)
- open the vis that you suspect are using this file AND try to edit the run-time menu. When this vi uses the run-time menu a warning will appear (cannot load rtm file, using default menu instead)
Kind regards,
Mark
10-23-2008 08:26 AM
10-28-2008 03:50 AM
When images are placed in the report these are generated in the temp folder. When the report is disposed, these files are not deleted. This will cause the temp folder to fill. I have modified my dispose report.vi file in vi.lib to solve this problem.
http://forums.ni.com/ni/board/message?board.id=170&message.id=364647
10-28-2008 03:51 AM
The append control image uses a millisecond timestamp to create a unique filename. When this function is called more then once in a millisecond the unqiue naam is not unique. Again, i have modified my dispose report.vi file in vi.lib to solve this problem.
10-29-2008 11:02 AM
Certain code can cause LabVIEW 8.6 to crash when run:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=365275#M365275
10-30-2008 11:43 PM
