10-01-2008 02:45 AM - last edited on 10-01-2008 10:37 AM by Support
10-01-2008 10:02 AM
Altenbach:
I think you skipped a millenia 🙂
-AK2DM
10-01-2008 10:17 AM
10-01-2008 05:53 PM
Setting a VI to "locked(no password)" does not "stick". (LabVIEW 8.6 only)
Next time the VI is opened, it is no longer locked.
See: http://forums.ni.com/ni/board/message?board.id=170&thread.id=359029&jump=true
10-02-2008 10:03 AM
The new version of the DB toolkit no longer handles closed recordset references in the Fetch Recordset Data VI:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=359049
10-06-2008 02:37 PM
LabVIEW 8.6 runs out of memory for trivial code that runs fine in earlier versions:
http://forums.ni.com/ni/board/message?board.id=170&message.id=359886&jump=true
10-08-2008 06:37 AM
Bug with animate windows when minimizing and maximizing
http://forums.ni.com/ni/board/message?board.id=170&thread.id=360297
10-09-2008 09:09 AM
Potential bug when using EXTended precision with an Intensity Graph in LabVIEW 8.5.
Unconfirmed... but have a look at this thread: http://forums.ni.com/ni/board/message?board.id=170&thread.id=360616
R
10-16-2008 06:46 AM
LabVIEW incorrectly reuses a buffer when using a shift register and reading from a cluster element and writing to it:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=362124#M362124
10-17-2008 02:38 AM
http://forums.ni.com/ni/board/message?board.id=170&message.id=362315
Bug where a saved back VI from 8.6 to 8.5.1 is not recognised in VBAI as valid VI. A native 8.5.1 VI is.
