NI Home
Cart Cart | Help
You are here:
Reply
Knight of NI
altenbach
Monthly Bugs, May 2012
Continued from the April 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
LabVIEW Champion . Oh, by the way, I work for peanutsKudos .
Member
testingHotAir
Re: Monthly Bugs, May 2012
Link
Typedef'd enum constant changing value at runtime in LV 11.0.
CLAD
Active Participant
Andrey_Dmitriev
Vision: IMAQ WindTools doesn't display properly in exe when called from buils spec
Proven Zealot
Jeff·Þ·Bohrer
Something went wrong...
[ Edited ]
Not quite sure what went wrong but, wrong it went.
CAR #353347
"All shall be well and all shall be well and all manner of things shall be well" -Julian
Member
Sci-Vi
NI-Motion VIs cause system clock to drift on PXI systems
The Windows system clock is running way too fast when calls are made (e.g. querying axis status) to an NI-Motion board. This has been currently observed on NI PXI controllers only. It can be critical as it of course also influences timestamps within LabVIEW.
A full description can be found in this forum thread.
Vincent
Member
Sci-Vi
Timestamp string formats misbehave
A series of bad behaviors for the "timestamp" string format :
First thread
Second thread
Vincent
Active Participant
P@Anand
Get Hierarchy Image - Bug
[ Edited ]
I got one today about getting the Hierarchy image. Here is the Original Post
I don't believe in Hard work. I love my work :smileyhappy:
Knight of NI
altenbach
LabVIEW 2011SP1f1 fails with 32 processor cores
Full discussion can be found here.
Member
Harlequinade
Failed to load or create probe with strict type def cluster in network streams
[ Edited ]
Probing network stream endpoint when data type is a type def cluster leads to error prompts
Link
CAR: 357568
Knight of NI
altenbach
Thread closed!
[ Edited ]
May is basically over. Let's continue in the June bug thread.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
