BreakPoint
Monthly Bugs, May 2012
Continued from the April 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 10
(14,428 Views)
Link
Typedef'd enum constant changing value at runtime in LV 11.0.
CLAD
Message 2 of 10
(14,397 Views)
Not quite sure what went wrong but, wrong it went.
CAR #353347
"Should be" isn't "Is" -Jay
Message 4 of 10
(14,338 Views)
The Windows system clock is running way too fast when calls are made (e.g. querying axis status) to an NI-Motion board. This has been currently observed on NI PXI controllers only. It can be critical as it of course also influences timestamps within LabVIEW.
A full description can be found in this forum thread.
Vincent
Message 5 of 10
(14,284 Views)
A series of bad behaviors for the "timestamp" string format :
First thread
Second thread
Vincent
Message 6 of 10
(14,244 Views)
I got one today about getting the Hierarchy image. Here is the Original Post
Message 7 of 10
(14,211 Views)
Probing network stream endpoint when data type is a type def cluster leads to error prompts
Link
CAR: 357568
Message 9 of 10
(14,135 Views)
May is basically over. Let's continue in the June bug thread.
Message 10 of 10
(14,098 Views)
