BreakPoint
Monthly Bugs, March 2016
Continued from the February 2016 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
(7,098 Views)
Raised CAR 576222 today through NI Support.
Description of bug:
When trying to Deploy an XNET database to an RT target using Linux RT, the deployment utility (either from XNET database browser or from an XNET database constant on the block diagram of the RT target) is unable to connect to the RT target to view/download new databases if the RT target has a password set. This is quite likely given that to use the remote file browser for transferring files on Linux RT targets requires a non-blank password (and this is a good security practice).
Workarounds:
- Deploy the XNET database programmatically from the host (e.g. PC) - this allows you to specify the username/password
- Remove the password from the RT target (this will prevent WebDAV access)
(blog)
(7,062 Views)
Received CAR #576775 today.
Description:
Missing documentation in LabVIEW help on "VI hierarchy" window symbols.
(for discussion in LabVIEW forum see here)
(7,022 Views)
CAR 578947: Saving VI With Auto-Indexed Cluster Connected to CLFN Configured as Adapt to Type Crashes With DAbort 0x24D61F21
http://forums.ni.com/t5/LabVIEW/BUG-LabVIEW-hard-crash-when-using-auto-indexing-For-Loops-with/m-p/3...
(6,903 Views)
Continued in the April 2016 bug thread.
This thread is now closed.
(6,792 Views)
