BreakPoint
Monthly Bugs, February 2014
Continued from the January 2014 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 8
(11,656 Views)
CAR 450163. Link is to the Champions Forum, sorry for those with no access.
LabVIEW crashes when programmatically creating instances of a VIT with XControls on the FP.
Message 2 of 8
(11,593 Views)
As described here, the option: "maintain proportion of window for different monitor resolutions", completely loses its mind when the original window is larger than the monitor and is later opened on a monitor with significantly higher resolution (Just guessing here. I don't actually know the resolution of the original monitor and have not explored all possible scenarios).
The math seems wrong!
No CAR yet.
(I corrected the URL, Thanks Jeff)
Message 3 of 8
(11,578 Views)
No CAR yet.
I get an unexpected error when I try to follow that link - it is quite a long URL! (I think it is linking to your reply, not the post?)
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 4 of 8
(11,554 Views)
Sorry. It seems by accident I pasted the help page paragraph that I quoted instead of the URL 😄
I have corrected the link. Here it is.
(....and here is the VI that shows the problem)
Message 5 of 8
(11,548 Views)
Discussed here:  http://forums.ni.com/t5/LabVIEW/quot-The-VI-is-not-executable-quot-on-the-development-machine/td-p/2...
Not sure if it is an actual bug.  Seems more like incorrect configuration, but with a number of people reporting the same issue, it makes me wonder...
Message 6 of 8
(11,435 Views)
As discussed here, xy graph cursors cannot be moved or placed if Y is NaN, even if X is not NaN. This apparently worked fine back in LabVIEW 2011.
No CAR yet.
Message 7 of 8
(11,402 Views)
February is basically over. Let's continue in the March 2014 bug thread.
This thread is now closed.
Message 8 of 8
(11,390 Views)
