BreakPoint
Monthly Bugs, February 2012
Will February be a good month for bugs?
Continued from the January 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 14
(9,862 Views)
Hello, I use LV 2011
Its not really a bug but it is very uncomfortable:
if you have the probe windows open (in german "Sondenüberwachungsfenster") then you have to click twice on a front panel or block diagram in (bottom) taskbar to let it open/appear.
This is really annoying
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 2 of 14
(9,827 Views)
EWiebe,
Please read the rules of this thread. This is a repository of links to bugs. Do not discuss your "likes" and "dislikes" here.
Message 3 of 14
(9,817 Views)
Left and top inputs of Excel Insert Graph VI are inverted. See here for more details.
CAR #337774.
Message 4 of 14
(9,787 Views)
disscusion here
"Should be" isn't "Is" -Jay
Message 5 of 14
(9,770 Views)
and I assume 2011 since R&D just learned about it.
see here.
Ben
Message 6 of 14
(9,738 Views)
When mousing over picture control the cursor will switch to whatever the last tool used in the Icon editor was.
See here.
Ben
Message 7 of 14
(9,727 Views)
bad link Ben
Seen here
Message 8 of 14
(9,718 Views)
The Label for the Formula Node and Mathscript nodes does not stay attached to the structure.
CAR# 339805
Message 9 of 14
(9,667 Views)
Adding items to an enum using the right click method Add Item Before or Add Item After causes the enum to walk across the screen.  This is depenedent on the justification set for the enum.
CAR# 339320
Message 10 of 14
(9,647 Views)
