12-01-2011 08:16 PM
Continued from the November 2011 bugs thread
The posting rules are as always:
12-08-2011 02:26 PM - edited 12-08-2011 02:28 PM
Not worth a post, not much to discuss. R&D can you edit the post with a CAR when you get it logged?
12-22-2011 01:45 AM - edited 12-22-2011 01:47 AM
LabVIEW 2011 (32-bit)
Programmatically changing the panel transparency value alters the value set in the Property Window (not expected or desired), but doesn't set the "dirty bit"
See this discussion.
12-28-2011 12:07 PM - edited 12-28-2011 12:08 PM
12-28-2011 04:34 PM
Saw this today- very odd no discussion really needed is there?
LabVIEW 2011.0 32 bit on Win 7 64
12-29-2011 01:34 AM
Why not? There are no repro steps, others might not be able to replicate it, etc. For good order, it's beneficial to have separate threads.
I'm assuming this happens because you show buffer allocations (both are overlayed over the terminal and they're drawn at the same point, so it's not a huge leap), but I haven't even tried it.
12-31-2011 04:03 PM - edited 12-31-2011 04:03 PM
OK, the year is basically over!
After we all have succesfully recovered from the NYE celebrations, let's continue in the January 2012 bug thread.
This thread is now closed.
