BreakPoint
Monthly Bugs, August 2016
Continued from the July 2016 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 9
(10,297 Views)
Wrong linestyle showing for plots in 2016 waveform charts.
CAR# 600682
Message 2 of 9
(10,212 Views)
Under certain conditions, a cursor locked to an xy plot goes haywire.
Details
Message 3 of 9
(10,167 Views)
As hinted in the discusssion of the bug right above, there is an omission for the "Map coordinates to xy"  method. It does not say what the boolean returns. (The method for the other direction is better described)
Map XY To Coordinates Method
Mentions that it "returns true" (Good!), but the boolean output is not listed in the parameter table (Bad!).
(It is listed under "data type", but I don't even know what the means here....Why does it even need a data type? Since it is always true, it carries no useful information)
Map Coordinates To XY Method
Does not mention the boolean output at all (except as the "data type"), even though it is there. (Bad!&Bad!)
Hmmmm.... Feel free to discuss in the linked thread.
Message 4 of 9
(10,165 Views)
The error seems to be only in the "Constraint Nonlinear Curve Fit" , details & work around here
> CAR 590370 has been filed to track this issue. This will be fixed in next release of LabVIEW.
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 9
(10,117 Views)
Many years ago, it was achnowledged that the output of reshape array is inconsistent if one of the dimensions is zero. Behavior is still present in LV2016. I wonder if there is a CAR.
Message 6 of 9
(10,081 Views)
Under certain conditions, feedback nodes fail to work with matrix data, breaking perfectly legal code, either at edit time or on first run. (details).
Message 7 of 9
(10,063 Views)
Continued in the September 2016 bug thread.
This thread is now closed.
Message 8 of 9
(9,994 Views)
CAR 590370 was fixed in LabVIEW 2017. See the 2017 LabVIEW Bug Fix List for details: http://www.ni.com/product-documentation/53584/en/
Message 9 of 9
(8,994 Views)
