06-24-2013 06:18 AM - edited 06-24-2013 06:20 AM
Here is something for the weekend 🙂
Hook up a loop/coil / long wire (with amp, migth involve soldering) to your soundcard and and listen to the mechanical radio 😄
LabVIEW implementations wellcome 😄
Alexanderson Day 2013 takes place on Sunday 30 June.
We will try to send a message with the old alternator at 09:00 UTC and 12:00 UTC. We start the transmitter about half an hour before we send the message. The frequency is as usual 17.2 kHz CW.
http://alexander.n.se/in-english/saq-transmission/
More links:
"Antennas successfully used by US stations reach from a 4 foot loop portable on Port Mahon Beach (Dover, Delaware) to a 100 meter long zepp at 22 meters height at Marietta, Ohio. Find your own solution and don’t give up after the first try!"
http://www.vlf.it/harald/strangerec.htm
http://on3jt.byze.be/saq-grimeton-reception-in-2005
http://en.wikipedia.org/wiki/Grimeton
And here is a mechanical receiver:
http://www.wireless.org.uk/mechrx.htm
06-19-2014 03:29 PM - edited 06-19-2014 03:30 PM
SAQ will be on air on Sunday 29 June. We try to start the transmitter soon after 08.30 UTC so there will be a test signal from about 08.40 UTC and a message will be sent at 09.00 UTC. A similar procedure will start at 11.30 UTC and the message will be repeated at 12.00 UTC. The frequency is 17.2 kHz CW.
Links see first post.
Only three times a year, a 1.6m diameter rotor is turning somewhere in Sweden, sending out a signal at 17.2kHz. (The last of it's own)
And you can detect that just with the soundcard of your PC. and a simple loop antenna, catching the magnetic field 😄
and this time, I wat to put my name on this list 🙂
So last time I use a degausing coil from an old CRT TV and HDSDR, this time I still have one week and already build my loop from 10m CAT6 cable and a 100nF Cap , feeding the mic input of my soundcard. The loop should be vertical mounted with the plane directed to sweden.
A wooden door will hold two turns of my old network cable, giving me 16 turns of wire. Fixed with clamps for outdoor tablecoth allow easy fine adjustments. 🙂
The capacitor(s) are in parallel with the loop and build a resonance at about 17.2 kHz. tuning the cap is done with the attached vi..
hold on ....
I forgot to mention: This time it should be done with LabVIEW!!
Starting with the simoultanious sound input output example I simply modified to send out noise and show a power spectrum.
So we also need a small sending coil. (I used a coil also harvested from the CRT TV with 22Ohm in series, however any coil should work.)
Next is a CW morse decoder...
I used a mp3 sound example converted to wav. these example a mixed down to 800Hz but shouldn't make a big difference at this stage ....
A LOOP IN detect the CW and convert it to positive or negative timestamps. looking at the distribution chart, the di and daa could be separated.
Well ... to a certain level..... still under development 😉
that's it so far.
Next post will be my wav for testing.....don't know if lithium allow it
06-19-2014 03:46 PM
Posting a 15MB WAV failed....
So here is a link to some soundfiles:
http://alexander.n.se/in-english/listen-to-saq/
I used Audacity to convert it to wav
06-25-2014 10:35 AM
Small update...
after some more crashes than wanted
here is a Listening software (still have to implement the morse decoder )
BUT you can listen to some CW if you select 800HzCW ... extra kodos for the first who decoded it 😄
06-25-2014 04:21 PM
06-25-2014 04:23 PM
06-25-2014 06:50 PM - edited 06-25-2014 07:00 PM
Right 🙂 I knew I can count on you 🙂 🙂
So here is a version with decoder 😄
Maybe some day I can decode it by hearing it. So ignoring the time to learn LabVIEW, drawing the decoder in LV was faster 😄
So software is almost done 🙂
Loop Antenna(s) ready 🙂
Maybe I add a high pass and try a audion like loop undamping with one or two PNPs ..... ther wasn't any solding involved by now 😞 😄
The LOCK-IN would allow to track the frequency .... just use the phase information
Need to make some nice icons ...
06-29-2014 08:59 AM
Sucess 😄 😄
12-13-2016 11:29 AM
After a fire in october they have fixed it 🙂
http://alexander.n.se/?lang=en
01-20-2017 01:43 PM
And set a record with over 400 listeners!
-AK2DM
