01-22-2016 04:28 PM
I think that Labview needs to change their logo, because it shows a picture of a red line and a blue line going in to an addition block. Everybody knows that when you add red and blue you get purple. come on guys.
01-25-2016 01:17 AM
I think they should first get rid of the Sequence Structure in the logo, which they already partially did. If we view the red as orange, it is correct: DBL + Int = DBL.
01-25-2016 07:47 AM
What no coercion dot? What is this LabVIEW 2?
(I honestly don't know if coercion dots were in LabVIEW 2)
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-25-2016 08:18 AM
I helped a new department get started and we needed a logo.
The company was too cheap to hire an ad agency so we had a contest.
01-25-2016 09:32 AM
That's brilliant... Works every time.
Although after watching Mad Men I'm not sure I would give them my money, either.
01-25-2016 10:28 AM
Who says that's an Add primitive? That's just a VI that uses the same icon. And those wires going in? There's no coercion because those are two LabVIEW classes whose wire appearance has been customized. And that supposed "sequence structure"? That's just a pasted image sitting behind the code. You can tell because there are no tunnels.
01-25-2016 07:13 PM
I don't know what you're all talking about. Clearly it's just two channel wires being added together.
01-26-2016 10:26 AM
Jacobson wrote:I don't know what you're all talking about. Clearly it's just two channel wires being added together.
Well, that's the 2016 patch. The great secret is that we've actually updated the logo every release of LabVIEW, but in a way that is completely transparent to our users. It was only an Add primitive in LV 1.0. It was a reentrant VI by 2.0. 🙂
04-05-2016 01:36 AM
@Jacobson-ni wrote:I don't know what you're all talking about. Clearly it's just two channel wires being added together.
I take it it's now set to Run when opened?
/Y
04-05-2016 02:53 AM
