NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Knight of NI
Knight of NI
Ben
Re: LabVIEW Minutiae (that may bite you someday)
In this thread Sunflower brings one of the "Bite you" scenarios regarding setting an AE as re-entrant and getting away with it... for now.
Ben
Ben Rayner
Who is NOT John Galt... yet... just building Rayner's Ridge
Proven Zealot
Jeff·Þ·Bohrer
Casting an int to an Enum (strict).
Who thought it would be so tricky?  Turns out that although I had expected each of the last 4 methods to be functionally equvellent I was wrong.
I guess you really do learn something new every day.
"All shall be well and all shall be well and all manner of things shall be well" -Julian
Active Participant
jcarmody
Make that constant into a U16 and Bob will be your uncle.
Jim
CLD
Active Participant
jcarmody
This NI document explains typecasting an integer into an enum.
Jim
CLD
Proven Zealot
Jeff·Þ·Bohrer
Just when I thought I knew something about LabVIEW!
Thanks Jim!  I wondered WHY- now I know.
Active Participant
paulmw
Jeff, you'd might like this too.
Coerce to Type
Active Participant
RobCole
Here is one that I also consider bad programming practice.
Default Enums
Setting a typedef enum as Use Default If Unwired always returns the FIRST (lowest number) in the enum. If you right click and create a constant, you will get whichever state was set to Make Current Value Default. This may be different from what the output is when left unwired. The default state is not shown and you have to look at the typedef to find out which will be the output.
Related - if someone rearranges the typedef enum (moves some other text to the first element) then the output of the unwired terminal changes. The state when you create a constant does not.
I think I would prefer a "Create Constant in Unwired Cases" option to use here.
     Rob
Trusted Enthusiast
SteveChandler
You have a value changed event for a combo box with Allow Undefined Strings deselected. You try to enter an invalid string into the combo box the system beeps an error at you and the control is not updated. As soon as you click somewhere else on the FP but the value changed event fires anyway. If you press escape prior to clicking away from the control the event is not fired.
Bug or intended behavior?
See this thread for more info.
LabVIEW 2012
Trusted Enthusiast
SteveChandler
Grr... It is early and I ran out of time to edit. The link points to the right thread but the wrong post. Just scroll up and see the first post. Anyway...
LabVIEW 2012
Knight of NI
Knight of NI
Ben
When working with the 3D Graph in the 3D Picture, I got bit.
A is not equal to B
Since I cut-n-pasted from an example I ASSumed that the wire was run behind the structure and worked with the value from "A" right up until I tested it.
Please note the tiny arrows indicating an Input AND an Output.
Can anyone else recall seeing another one these anywhere else?
Ben
Ben Rayner
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
